G-BODY LIFTS
311 replies to this topic
#301 Q. Walt
  • Moderators
  • 644 posts
    1983 Cutlass, 1985 Cutlass Supreme, 1990 Caprice Classic, 1996 Caprice 9C1, 2003 Avalanche Z71
Posted 14 January 2012 - 05:38 PM
View Postveltboy618, on Jan 14 2012, 10:19 AM, said:
Anybody got pics of a front notch on a car to get a better turning radius on big wheels?
Here's the link and the post:
http://www.kingofthestreet.com/forums/inde...p;#entry1152220
View PostT TOP TONY, on Dec 14 2011, 09:52 PM, said:
alright heres some of the build pics including the frame notch (some complete some not)
cut into the trunk and back seat area about 3 1/2" then plated back up and seam sealed
front notched in front of body mount at 90degree angle
rear notched from body mount to body mount (arch portion)
boxed back in only about 1.5" wide now
allows for no adapters or lift in rear and wheels fit totally inside
front
rear
bad angle on grass
hope that answers enough questions
Posted Image Posted Image Posted Image
#302 Q. Walt
  • Moderators
  • 644 posts
Posted 14 January 2012 - 05:54 PM
You forgot that you've asked this question before?
http://www.kingofthestreet.com/forums/inde...showtopic=71260
View Postveltboy618, on Feb 10 2009, 01:35 PM, said:
If anybody got pics of a frame that was notched could you post them for me ?????
Thanks
View PostSt. Pete, on Feb 10 2009, 05:18 PM, said:
Kinda the finished shit of the car this was done too (a regal)
dont really worry bout shit else in this pics because the rest of the shit doesnt reall apply, cuz alt of ya'll go fuck around and get confused and get headaches and shit (some of ya'll real retarded down here LOL)
red= that supporting cross member after the notch
green = shocks
white=coils
yellow=trailing arms (upper & lower)
View Postveltboy618, on Feb 10 2009, 05:26 PM, said:
Now show me how to do the front
View PostSt. Pete, on Feb 10 2009, 05:30 PM, said:
Paypal = l_jizzm@yahoo.com
$50
and it'll be up ASAP
not joke'n
Edited by Q. Walt, 14 January 2012 - 05:57 PM.
#303 84cuttyboi
  • 70 posts
    1984 cutass supreme
Posted 24 March 2012 - 01:41 PM
I'm about to get some 22s for my 84 cutlass how to I give it dat donk look what type of springs to get ? I don't want it sittin too low but I don't want it supa high to where da rims look like 18s ima try to go with some 285/45/22
#304 UCitEnt
  • 1 posts
Posted 06 June 2012 - 06:06 PM
View PostYoungDeezy510, on 18 January 2008 - 06:01 PM, said:
g-body front lift springs $100
g-body rear lift springs $100
Extended upper arms $400
rear air shocks $100
thats only $700 and you was tryin to spend $600
Cup kit goes for $100 to $150
arms $400
air shocks $100
thats $650
fabtech s-10 lift spindles $425
extended trailing arms $350 to $450
thats $875
UCL 5" complete lift kit $795
cups
front arms
trailing arms
shocks
thats all i could think of
I've never tried the cups but I've tried the spindles on a 87 SS Monte with Cooper 295/35/24 tires and the ride pretty much remained the same...and had plenty of room to spare could of easily put 6s on, But Im trying to think of some new options for my 84 Hurst Cutlass with 275/25/24 tires not really looking to go the spacers/cups route, thinking about the 3" lifting spindles with a 1" drop spring
#305 dmurria
  • 2 posts
Posted 28 July 2012 - 04:34 PM
Hey I just got an Buick regal and want to put 28s on it. I saw that the wheel wells are kind of bigger then most gbodys. I know I'm going to need new springs, would the moog 5608 help lift it in the front since i have a big block and they have a higher spring rate and use the moog 5391 to help lift the rear (I got all my spring rate info from http://www.maliburac.../coilspring.htm) Would I be able to lift it enough with caprice spindles, notching the front and rear, rear trailing arms, and the adjustable cups from ucl??
Edited by dmurria, 28 July 2012 - 04:37 PM.
#306 6os74211
  • 1,732 posts
Posted 02 August 2012 - 12:23 PM
hey look.my cutty on 30s now but i still got the same lift from the 8s.desent stance but im lookin for a better ride.whats new?what i have is a lifted c1500 spindle modified the upper an lower balljoint.extended upper control arm a lil bit. an modified the sleeve to work a cutlass tie rod on 1 side and chevy on the other.Attached File  IMAG0019.jpg   1.11MB   6 downloads
Attached File  IMAG0020.jpg   983.78K   4 downloadsAttached File  IMAG0021.jpg   1023.23K   6 downloads
Posted ImagePosted Image
#307 dmurria
  • 2 posts
Posted 04 August 2012 - 06:12 PM
View Post6os74211, on 02 August 2012 - 12:23 PM, said:
hey look.my cutty on 30s now but i still got the same lift from the 8s.desent stance but im lookin for a better ride.whats new?what i have is a lifted c1500 spindle modified the upper an lower balljoint.extended upper control arm a lil bit. an modified the sleeve to work a cutlass tie rod on 1 side and chevy on the other.Attachment IMAG0019.jpg
Hey I got a few questions, if you dont mind answering them. What did u do to get that much lift?are those stock c1500 spindles? I saw on the layitlow forum they use b body control arms to, or is it easier to extend extend the controls arms and how did you extend your trailing arms, I'm in high school but i know how to weld and have access to a full shop so i can do most of it myself. Could u email me the help to djmurria@gmail.com
Edited by dmurria, 04 August 2012 - 07:08 PM.
#308 6os74211
  • 1,732 posts
Posted 07 August 2012 - 07:33 AM
the aftermarket c1500 spindles.i just opened up the holes for balljoints. i extended my trailing arm wit a plate in the middle.spindle an a couple knucles all i got.
#309 KermitMonte
  • 288 posts
    2012 Camaro, 1984 Monte Carlo
Posted 07 August 2012 - 06:40 PM
How do you get a g body to fit 255/30/26 with very minimal cutting? Can it be done without extended control arms?
#310 6os74211
  • 1,732 posts
Posted 08 August 2012 - 02:30 PM
gotta trim a lil,
#311 KermitMonte
  • 288 posts
Posted 09 August 2012 - 08:51 AM
I didn't type my question right. How do you get 255/30/26 to fit on a g body with as little lift as possible? Just got a set and trying to redue lift and lower my car to fit them nicely. Without extending control arms, spindles if its possible??? Me and a friend was having a discussion if it can be done and he said you can fit them with your stock suspension but with lift springs. I don't think that would be enough clearance for 26s because g bodys are so fucking small, I thought you had to extend the control arms and use a larger spindle UNLESS you was using 275/25/26....what yall think?
Edited by KermitMonte, 09 August 2012 - 08:54 AM.
#312 6os74211
  • 1,732 posts
Posted 02 September 2012 - 09:31 PM
shid just slap em on there.trim a lil bit in front of tire. a couple big knuckles in front an take out bump stop an knotch frame.
