Subwoofers
3072 replies to this topic
Posted 30 July 2009 - 05:31 PM
*Subwoofer Suggestions
*Subwoofer Reviews
*Subwoofer Problems
Ask here. PLEASE don't create a thread for 1 question, we already have too much trash in this section.
Posted 04 August 2009 - 04:31 PM
I have a soundstream xxx 6500 amp. I was trying to decide which subs to run with it. I'm debating on Solo-x's, Orion HCCA's, or Digital Designs. Do you all have any suggestions on which subs I should go with?
Posted 04 August 2009 - 05:23 PM
solo x or hcca
Posted 04 August 2009 - 05:51 PM
solo x
and that amp doesnt get live till under .5 and over 16 volts
Posted 04 August 2009 - 06:28 PM
View Postcaps, on Aug 4 2009, 10:51 PM, said:
solo x
Think i should run two 12's or 1 18?
Posted 04 August 2009 - 06:55 PM
depends on your ohm load and your voltage. on a 12v system its not enough power to really push either
Posted 04 August 2009 - 07:44 PM
Whats the real ratings on that amp?
Posted 04 August 2009 - 10:13 PM
My electrical system will be upgraded. I really don't want to run a .5 ohm load daily. So I'll probably do 2 dual 4 ohm 12's. The box for an 18 would be a bitch to handle if I needed to take it out.
Posted 05 August 2009 - 07:22 AM
12v=no more than 4K
Posted 05 August 2009 - 08:14 AM
I GOT A JL W6 12 SUD ,ON THE OUTSIDE RUDDER ITS IS CUT HOW CAN I FIX IT AT A REASONABLE PRICE , I WENT TO THIS SHOP AND THEY WANT JUST ABOUT AS MUCH AS THE SPEAKERS WORTH TO FIX IT .
Posted 05 August 2009 - 01:02 PM
super glue it cheap fix or you have to recone it wich is why it cost so much
Posted 05 August 2009 - 02:59 PM
100% silicone
Posted 05 August 2009 - 08:39 PM
View Postcaps, on Aug 5 2009, 02:59 PM, said:
100% silicone
This. The silicone will seal the tear, and still be flexable enough to move with the surround.
Posted 05 August 2009 - 09:01 PM
go with what they said nvm what i said it makes sense glue would make it too stiff to move didnt really think that through
Posted 05 August 2009 - 10:32 PM
and make sure to use clear silicone, and seal it from both sides of the cone
Posted 06 August 2009 - 04:29 PM
Posted 12 August 2009 - 07:21 PM
Is this amp enough 2 power 2 fi 18 BLs or Btls
http://www.sundownaudio.com/index.php/prod.../saz-3500d.html
Posted 12 August 2009 - 08:55 PM
Yes sir!
Posted 12 August 2009 - 09:13 PM
View PostAudio Advice, on Aug 12 2009, 08:55 PM, said:
Yes sir!
x2, though in my opinion, it would be better suited for the BLs. BTLs are nice loud low subs, but they are power hogs. They will function fine with 2000w and under, but above that is when they really begain to cut loose.
Id rather use the 3500 and work the shit out of the BLs and keep the gains low.
Posted 12 August 2009 - 10:27 PM
x2 on teezy.
Got me some old school lanzar!!!!!!! FTMFGDSOBW!!!!!!!!!!
