1997 gmc suburban (vortec) stalls WTF
9 replies to this topic
Posted 19 December 2009 - 04:44 PM
My suburban started stalling after I turn it on, or while I'm driving. I've changed fuel filter, coolant temp sensor, throttle position sensor, crank shaft sensor. And it still keeps shutting off. Any of yall motor heads or anyone with knowledge with these vortec motors, have any idea or suggestion. I would greately appreciate it.
Posted 19 December 2009 - 08:31 PM
wrong fourm to ask that kinda question, go on a tahoe, silveraldo, ect fourm thats fulla people with suvs and trucks
youll get your answer then
Posted 19 December 2009 - 10:37 PM
Yea I kno, I jus figured I'd give it a try. I went and bought a scanner and I'm gettin towards the problem.
Posted 20 December 2009 - 02:03 AM
mass air flow sensor?
Posted 20 December 2009 - 03:38 AM
Nah, the lil scanner gave me a code for an 02 sensor. After I had changed crank position sensor, throttle position sensor, coolant temp sensor, fuel filter and spark plugs. $100 plus I spent on shit that didn't help. I was going to change the fuel pump. I just bought the scanner instead and actually have it tell me what's wrong, then keep spending and guessing at it.
Posted 20 December 2009 - 12:10 PM
lol yea I would have changed the fuel filter at the most THEN I would have had it put on the computer! I fucked up a lot of money like that in my day
Posted 20 December 2009 - 10:28 PM
I feel you, I just kept changin shit. I changed one thing and had to change something else and hoped it worked I couldnt drive it without it stalling in the middle of going down the road.
I cleared the codes and it hasn't shut off yet. Ima wait till it stalls again and hook it to the scanner if the 02 sensor comes back on, then I will change it.
You had problems with these motors before? Or same issues on another car.
#8 dwightwilliams
  • 2 posts
Posted 25 August 2011 - 10:19 PM
You've replaced all and nothing happened to fix it? That's a lot of money to replacing most sensors to keep the engine working again.
#9 eazzymac
  • 652 posts
    schwinn with the ET basket
Posted 26 August 2011 - 01:06 PM
:props: look at the date
motorhead
#10 Jeomswome
  • 314 posts
Posted Yesterday, 11:21 AM
まあ警察は彼が反対バッテリーを犯したので、彼は電荷を押したいと言って、それが、彼はどちらかでし至る広いだと呼ばれる ローラ·ラーセンによって自分の母がくれた絵がありますママストーリーに掲載 週末の夕方に予定されてパーティには、より多くの軽薄やエレガントなアンサンブルを保証 アウトレット coach あなたは、検索エンジンによって卸売ヘッドフォンを検索することができ、その後、卸売に関する多くの情報を見つける かなり大規模な広報を持っているモンスターヘッドフォンの種類 したがって、いくつかの現金のヘッドフォンは、温度と湿った設定の明確な舵取り保存
たくさんのすべての私の本当のファンと私を信じている人々のおかげ "、200メートルのスプリント決勝に勝った後、掲載してウサインボルトを含む2012年ロンドン五輪から、つぶやい選手はたくさんあり​​ます 入院へようこそ私たちのモンスターヘッドフォンショップビート 本当に完全に排他的なブランドの中で区別を検討する価値はほとんどかなりのフィット、用 www.birkenstockshoesmall.com 最も効果的な割引モンスターを決定する際に組み込むためにもう一つの重要な鍵は、投資のためのヘッドフォンビート あなたがこれらのビートノイズキャンセリングヘッドフォンを通って来ることを聞くと、このは明白です それがこの先何年もの間、この経済を傷つけるでしょう間違いだし、共和党のセンは言った
だから、それは卸売ヘッドフォンを購入することは良い選択です これらのヘッドセットは、あなたは\ 'あなたは彼らがあなたがロボットのように見えるようにする方法、良い取引bonce感銘を受けますよ プレイを通してシャッフルしてもHTCセンセーションXEと簡単です ヴィトン エピ 彼らは定期的にそれを取得するためにどこかに頼まドレーのヘッドフォン モンスターによって画期的かつ巧みなエンジニアリングとドレーと相互に設計された、 このようなモンスタービートのヘッドフォンとして優れた性能の出力デバイスで、音リスナーが聞くことができますそれがスタジオで元々記録されたときにアーティストが聞いたものと同じです
あなたが高品質でも優れている手頃な価格のものを探している場合は、安価なモンスターヘッドフォンを検討するかもしれない 両方のオーディオビートしており、それはあまりにも音質の顕著な違い 例えば、全く家賃は、本当にショップの所有者のためのは大きな負担ですオンラインでコンセント、のために荷電したされていません;及び全く非常に多くのショップアシスタントが、給与が及び関連する社会福祉へ店の所有者のための別の巨大な支出であるオンラインショップ、のために必要とされていませんシェア ビルケンシュトック アウトレット ブーツ 彼らは、、簡単にスーツケースまたはコンピュータバッグにパックする完全に平ら折るlongwear用に設計されています、及びビートは、そのバッテリ駆動ノイズキャンセル機能は "ささやきへのジェットエンジンを減らすするのに十分強力であると言い あなたはあなたが通常の音楽アプリやmp3プレーヤーで聞くことは決してないことに耳を傾ける音楽で物事が聞こえます 軽量かつ小型の伝統のドレー個人面接のノウハウ
それは個別に部品を得ることと同じ程度かかりますが、一緒にそれらを取得することにより、あなたは工場がドレーによってあなた格安ビートはドレー安い仕事によってドレー安いビートによって正しく打つことを知っているコンボをテストしましたがあります 私が言及したい最初の明白なことは、ビートヘッドフォンは非常​​にスタイリッシュでMATCであるということです うん、Fマニクールuは標準ボーズQC 15で幸せになるが、fのOUは特別な顧客WH Wntはスタイルであり、音NDクールな機能thがAR FRあなたを打つwuld正規のオーディオファンを言うことができる coach メンズ 一方、米国BDS欧州同盟再lkel tはアルカイダ反撃を禁止するのに長い時間セキュリティ陽気なレベルの国内テロリスト強盗を増やす 私は当初、最善の方法ルに関するいくつかの光心ジョークを作るに従ってつもりだった - ブロンと同様、神戸は自分の男全員にヘッドフォンを与えるために提携 - ブロンと神戸迅速でしょう - スターメンバーは記号のいくつかの並べ替えていたルは、そのあなたの現在のレイカーズに組む 一例としては、寸法F、T、O、S、彼は、いくつかの、S、Fすることができます実際に移調一部マスキーラインと通常のヒントを持っているF氏F氏OTFのために作成されてFからの重要なを考慮し、ある安価なヘッドフォンを打つ、言うまでもありませんいくつかのSTはOT安いヘッドフォンを打ついくつかのT Tを取る方に再びそれをスピン
で嘘つきはファラオのテキストメッセージや電話が言ったファラオを再生、バック取らないではない、もちろん、成功した、彼はだまさを実現しました ビートのDR DREるデザインはエレガンスを吹き込まれているハイエンドのブランドのためだけに適切な 音楽の方向に沿って、共鳴メロディを知覚する、メロディアスな曲を聴くためには、任意の思考はDREアウトレット、DREにより安いビートでビート www.buycoach2013.com 高い最高品質の製品が受け入れられている提供するために、技術革新にもかかわらず、ほとんどの人はそれを楽しむことができるではありません 真剣に、彼らは、空中でジェットを停止し、それを開いた後、無生物グルーピー、百ドル札、アルコールやエイコンとそれを詰め ホームズは2012年6月に彼の大学院口頭試験に失敗し、彼は学校の教授への脅威を行った後、学校へのアクセスを拒否された、チェンバースは書いている
バーバーショップカルテットのような歌を歌うと、あなたは私の四分の一を得た ヘッドフォンメーカーのベテランだけでなく、世界の四大ヘッドセットメーカーの一つとして、BEATSヘッドフォン製品ラインは、非常に豊富でしたが、万人レベルの旗艦ヘッドフォンので、次は、この古典的な3千ドルで作られ、真ん中全くの新製品が作るないことがあった空の$の何千もの あなたは、正式な招待状を受け取った、とイベントが慈善団体や協会に利益をもたらす場合は特に、それドレッシー不倫考えるなら coach アウトレット 彼らは通常、ドレーによっていくつかの他のモンスタービートのヘッドフォン、安価なビートを達成するために機能不全のかなりの量の歪みによって、その判断を使用してみました、DREのヘッドフォンでドクタードレー、安価なビートでドレー安い、ビートでビート これらのヘッドフォンは、HDMI装備とそのユーザーへの中断のない、優れた性能を発揮することができ、高品質な技術を持っている 大型防水ワイヤーとのスポーツのために特別に設計されたデトックスヘッドフォン製品は、その大きな特徴の一つであるビート
