1989 chevy caprice
Started by 89chevyrider, Mar 02 2011 05:25 PM
3 replies to this topic
Posted 02 March 2011 - 05:25 PM
wat should i do to the motor, trans and rearend to make it be able to launch fast and burnout easily. car is on 26's also.
Posted 02 March 2011 - 08:32 PM
Add at least some 3.42 gears and a posi to your rearend. What all is being done to the motor? That determines how strong the transmission will have to built. If you just dropping in a stock 454 then a good trans rebuild, a converter w/ a lil more than stock stall, and a tranny fluid cooler should be fine.
Posted 18 November 2011 - 03:48 AM
This is a very huge wheel rim upgrade! Do you need to replace most of the suspension to put this wheel on? I just wanted to know coz it looks like the cars rake elevated drastically.
Posted 18 November 2011 - 07:51 PM
You should replace all of your suspension components anyway just because their probably worn out and because of their age. What size tires are you running on the rims?
