whats so good about an lt1
Started by 26zH03, Jun 10 2011 06:03 AM
11 replies to this topic
Posted 10 June 2011 - 06:03 AM
Tryna learn somethin ya dig, what's all the hype about the lt1 engine. And what's the difference in the lt1 and ls1.
yungin only 19 str8 gettin it, plus i got swagger.
Posted 10 June 2011 - 07:59 AM
Absolutely nothing. It's just a SBC 350 w/fuel injection. Some had factory aluminum heads (F-bodies & Vettes), they also had a different cam and heads (iron heads) than the B-body LT1s had. The LS1 is vastly superior to the LT1, but it also cost more. The LS1 is lighter (aluminum block and heads) than an LT1 (iron block and iron or aluminum heads), the LS1 has much better aftermarket support than the LT1 has ever had, and the LS1 makes more power than the LT1 stock, so just imagine it with upgrades.
*LT1s also have one of the worst ignition systems known to man because the optispark distributor sits beneath the water pump. That was just terrible engineering. The picture in my sig the LT1 in my '96 9C1 Caprice; you can see the distributor behind and between the crank pulley and water pump.
Edited by Q. Walt, 10 June 2011 - 08:02 AM.
Posted 11 June 2011 - 12:53 AM
I juat wanted to know because all I see is lt1 this ls1 that. So I wanted to know. Thanks big bruh
Posted 11 June 2011 - 01:44 AM
It has it's faults (opti) but it's a good ass motor.
Posted 27 June 2011 - 03:20 PM
I heard frm a fee people that u can put the distributor in the bak of the lt1!
Posted 28 June 2011 - 12:27 AM
Don't think so. I've seen a kit for a front mounted distributor on an LT1 but it was expensive. Honestly, I'd rather just buy a TPI kit for a regular SBC 350/400. I don't really like LT1s, but that's what came in my Impala SS and 9C1 Caprice.
Posted 01 July 2011 - 04:12 PM
if you converting to a carb you can put the distributor in the back you just need the intake and carb
Posted 02 July 2011 - 06:20 PM
Posted 03 July 2011 - 08:13 PM
My buddy told me he was breaking his down the other day and there is a hole in the back that has a plastic cap in it for the distrib
"There's some money in these streets but you gotta be careful, know who your friends are and what reason they there for"
