lift 2003 grand marquis to fit 24's
9 replies to this topic
#1 jwhezzy2003
jwhezzy2003
  • 7 posts
Posted 26 June 2011 - 11:34 PM
I have a 2003 grand marquis that has factory air ride in the back. I bought some 24's that someone had on their magnum. I think the offset is low on the rims. While my 2003 grand marquis has a high offset. So the rims poke out about a inch.
The rims are 24" U2 35 rims that where on a dodge magnum.
How can i get these rims to fit? will having the wrong offset hurt anything or mess something up?
Should i just put knuckles in the front and raise the air ride all the way up in the back?
#2 Cartoon
Cartoon
  • 15,674 posts
Posted 27 June 2011 - 12:26 AM
knuckles in the front.......... the rear should be fine at stock height especially since you have the air to adjust it when you have alot of people rolling with you......... the rims polking out won't hurt anything but the look, just doesn't look good imo, but hey gotta do what ya gotta do
#3 jwhezzy2003
jwhezzy2003
  • 7 posts
Posted 27 June 2011 - 07:33 AM
how many inches would 2 fat knuckles (that are suppose to go in the rear) lift the front of my 2003 grand marquis? I know I put two in each spring but how much of a lift is that? I want to do atleast 3 inches until I order and install my lift cups.
How hard is it to install cups by the way.
#4 Teezy
Teezy
  • 1,928 posts
    04 Crown Vic
Posted 27 June 2011 - 08:26 AM
Here is a couple pics of my 04, (2) fat knuckles on each side, and a set of spacers in the rear, (doesnt have the air ride)
As you can see, its def not 3 inches, measured from the ground to the fender, id say its more like 1 1/2" to almost 2",
(2) fat knuckles per side is perfect IMO, matter of fact when I had one per side I was good, but I was worried about fenders drops and I was on the Hwy alot so went with 2 for peace of mind.
Cups are easy on the CV/Mercs, but if your looking to lift that front, the only option is the kit UCL sells its a little different than the cup lift.
#5 jwhezzy2003
jwhezzy2003
  • 7 posts
Posted 28 June 2011 - 02:33 PM
which UCL item is it? do anyone has a link to the item needed.
#6 SAU Marquis
SAU Marquis
  • 78 posts
    2003 Grand Marquis
Posted 28 June 2011 - 03:45 PM
Man I have an 03 marquis with u2 35s in the mid offset +18 and mine poke out... I put cups in and it is a moderately difficult job unless you have some mechanical skills... you can go see mine in the vic/marquis lift thread a couple pages back... honestly though I would listen to ^ and just put a couple knuckles up front for 24s
#7 jwhezzy2003
jwhezzy2003
  • 7 posts
Posted 28 June 2011 - 04:03 PM
what page is yours on its alot of car in that thread...lol...u still have the rims on? are they 24's? and did having the wrong offset mess up anything in your suspension?
I put 2 knuckles in their today (which is an easy job by the way) and now I hear like a little squeek like noise...sounds more like metal on metal rubbing.
Did that happen to anyone else?
Edited by jwhezzy2003, 28 June 2011 - 04:05 PM.
#8 jwhezzy2003
jwhezzy2003
  • 7 posts
Posted 28 June 2011 - 04:42 PM
NEVERMIND
i seen pics of ur car. Your joint sit just like mine. Mine is blue i will take pics latter.
Did the rims mess up your suspension (like ball joints and alignment problems).
#9 SAU Marquis
SAU Marquis
  • 78 posts
    2003 Grand Marquis
Posted 28 June 2011 - 06:25 PM
Naw it ain't cause no problems and a little sqeak here and there isn't anything to worry about
Id be more helpful if I was at home but I'm on vacation in galveston
Edited by SAU Marquis, 28 June 2011 - 06:26 PM.
#10 jwhezzy2003
jwhezzy2003
  • 7 posts
Posted 28 June 2011 - 07:05 PM
My 2003 Merc Grand Marquis on some 24's. They are 24x9 U2 35 on some 255/30/24 tires.
Attached File  side1.jpg   40.98KB   10 downloads
had to raise it up alittle. Used 2 knuckles per coil. Now she sittin good.
Attached File  side2.jpg   47.67KB   9 downloads
Attached File  front1.jpg   50.49KB   8 downloads
wheels was the wrong offset so they poke out alittle.
Attached File  front2.jpg   50.53KB   9 downloads
Attached File  backside1.jpg   44.82KB   7 downloads
smoked out da tails.
Attached File  backside2.jpg   41.18KB   9 downloads
Attached File  frontside1.jpg   48.17KB   9 downloads
Attached File  frontWheelsTurn1.jpg   45.84KB   9 downloads
Attached File  hammerFender1.jpg   49.35KB   8 downloads
had to hammer in the front and back of the front fender alittle bit. Nothing a little sledge hammer couldn't fix.
Attached File  hammerFender2.jpg   44.54KB   13 downloads
