lambo doors bolt on door sicks out more then fender
2 replies to this topic
#1 trife2ill
  • 10 posts
Posted 05 February 2012 - 06:32 PM
need help fixing prob i got a 1985 caprice i put the lambo on and the door sticks out more then the fender any help a be great a.s.a.p thanks
#2 Toolddads
  • 126 posts
Posted 06 February 2012 - 03:00 PM
encuggicymn hogan outlet
#3 ATB89
  • 5 posts
Posted 11 February 2012 - 02:06 AM
sounds like who ever put them on put them on wrong. But you should be able to take off the bolts at the bottom of your fender and add a few washers under the metal of the fender. that will bring the bottom of the fender out and it should help but if its sticking out more at the top theres nothing you can do, if its a weld on kit. if its a bolt on kit you should be able to take off the door grind out the outside bolt holes towards the car and then put the door back on. hope that helps
